e60 spacers?
Ok guys I'm new to all this and been searching but I'm still asking my self some questions.
First off I just installed d2 coilovers and 7 series rims 19x9+24 And 19x10+24. as soon as I dropped it the front tires started to rub on the coilovers so I raised it back up. I got 5mm spacers just to see if I drop it again it will solve the problem its still close to coilover I was wondering if anyone had this experience before and just kept the 5mm spacers and have had no problems rubbing. I have 245/45/19 front tires . And my second question might sound dumb but here it goes. So if I have 24 offset and get 10mm spacers will the rim be considered a 14 with the adapters? |
that is correct about the spacer and offset. if the offset of the wheel is ET24 and you put a 10mm spacer on, it would be ET14. also your tire size should be 245/35/19 for the front according to specs.
Ok so if everything clears with 10mm spacers and I get no rubbing issues does that mean that if I was to get new rims with 14 offset I wouldnt need spacers?
