e60 oversized tires
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
When the 2010 528i was launched it had 225 50R 17 sized tires.
Can the body handle 235 50R 17 tires without wheel well modifications?
Will putting on wider tires throw new error codes?
That is a taller tire, if you want to go wider, go with a 40/45, a 50 series is taller. Honestly, dump the 17's and run 255/40r18. They will fill the well nicely without going to low. If you want to go wider a 245/40r17 would be about your exact size but wider.
My Ride: 528i
Engine: N52k
I would like to go with a wider 245 tire you suggested. I worry that it will hit the inside of the quarter panel.
Do we know that a ton of guys have put 245's on their stock 17 inch wheels?
Administrator
My Ride: 530xi
Engine: N52
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
My Ride: 535i xDrive Touring w/Logic 7
Model Year: 2010
Engine: N54
Yes, I've heard the pre-LCI cars had 245/45-17" as an acceptable uprated size. I'm looking to make the same move on my 2010 e61, but such specs are no longer printed on the driver's door panel.
The rotating radius is extremely close between the two sizes, the only issue is where the 7.5" rim is fine with the 245 width tire (so a stretch/width issue).
any xDrive/e61 people?
Administrator
My Ride: 530xi
Engine: N52
Note that it's not the rolling circumference comparison between two separate sets of tires that matters, it's the rolling circumference among the four tires of the same set that matters.
Model Year: 2010
Engine: N54
Of course, but if you want to avoid speedo/electronics issues, your replacements better be damn near the stock rolling diameter.
