My Ride: E60 2006 530xi 84K mi., Premium, Cold pkgs incl rear seat heating, HUD, Logic 7, Adaptive and trick interior lighting, Pro Nav, N52 engine.
Back spacing for aftermarket wheels
Ok, I'm looking around for some aftermarket wheels for my 2006 530xi. I'm down with the whole offset, lug spacing, wheel bore, width height etc etc. What's the deal with back spacing? I'm moving up from a 17" to an 18" square setup. Here's where I'm at regarding the wheel I'm looking at......
Backspacing is simply the distance from the extreme back edge of the rim to the mounting surface. In your case, there is 6.13 inches from where the wheel mounts against your rotor to the outside of the rim. Since you are planning to mount a 245 tire, you should be okay fit-wise. But I don't like your choice of wheels for two reasons:
The proper E60 hub bore is 72.5, which means you will need to use a .10 concentric ring to compensate. Otherwise, your wheel will vibrate at higher speeds.
The fact that your intended purchase will accommodate different bolt patterns means that you are looking at a "universal" rim. To some people it might not matter, but I hate the look of wheels with all of those extraneous holes.
I think you would be a lot better off with wheels that properly fit your car, but that's just me. You asked for opinions. Here are some OEM possibilities you might consider instead: All BMW wheel styles 5 | BmwStyleWheels.com Check Craigslist and the bimmer forums for used deals.
OK but
We're talking .1 mm here not a full mm. I've actually seen that OEM wheels center bore are closer to 72.56mm . I could see needing rings for something like a 74.1 bore but one tenth of a mm? Also, it's not a universal lug spacing wheel, it just comes in all the different lug spacings. I appreciate your feedback. Just trying to clarify a few things. Here's a pic of said wheel to show the lug spacing. I think they look relatively cool (I'm 66 y/o LOL) and are rotary forged which is better than the gravity cast junk out there. Whaddaya think?
Thanks for the clarification on the lug spacing. I think you still may need some sort of ring for the hub however. But go for it and try them and see. You can always add them after you experience the vibrations. Nice wheels.
Originally Posted by spazzz
those will be A OK
OOOOOOooooo NICE !! Couple questions........What kind of tires you running on your car? Did they supply lug bolts or are you using stock ones? If supplied, did the bolts fit ok? Thanks in advance and stay safe.
That is my daughters 08 328xi and Nokian ZLine A/S P235/40R-18. I bought some Aodhan lug bolts I think 28mm long. Stock is 26mm I believe.
She is using the stock beat up bolts on the stock 158s with Blizzaks in winter.
Those are the LS002, 18 x 8, 35ET.
Those Nokians were 413.86 delivered from Simpletire
What are you thinking for tire brand and size?
For a 245/40/18 Nokian Zline delivered it is 404.69, I didn't check to see if there is tax. Again from Simpletire.
I have ordered three sets from them in the last year and they have had the best price
I'm looking at either Michelin Pilot Sport A/S 3+ or Pirelli P Zero All Season Plus........both in 245/40-18. I have 17" Yoko Avid Ascends on my stock style 138s that I'll probably use for winter. How does she like those Nokians? I had heard they have a pretty rough ride. I've never used them. Curious as to your thoughts on those.
She had Continental run flats before so they are better.
I drove it briefly and thought they were okay, she likes them.
Maximum bang for the buck from where I am standing. We will see in 3-4 years maybe less, if noise develops.
