Another wheel fitment example
I'm looking for a set of winter wheels and found some style 262's and wondering if they would fit my 535xi. Based on my current style 277's I don't think this should be a problem. I looked at willtheyfit.com and it seemed to be okay but since you guys are more experts at this than me, thought I would throw it your way.
Last edited by kd7iwp; 09-05-2018 at 09:10 AM. Reason: Accidentally linked to a porn site instead of a wheel site!
Administrator
If the Style 262s are staggered, you may have a problem since the rolling circumference needs to be the same on all four corners on a AWD car. What tires are you planning to use?
Administrator
Just a note of caution... a 205 tire may be too narrow for the weight of a 535 wagon. Check the load range of the tire. Generally, 225s are the narrowest you can go on an E60.
Also found some Style 159's from a 335i with 225/45/17 winters on them that I'll look into. Load rating should be fine. Offset is 34 but I think that should be okay. They'll stick out a centimeter more than my current ones but think that should be okay.
