530Xi fitment
Old 04-03-2013, 07:46 PM
Ted in T.O.'s Avatar
Default 530Xi fitment
Okay so I am confussed with all the info I am reading on the net. I have a 2006 530xI 6 speed. I have Style 135 wheels with an offset of 43 square. My dilemma is I got a line on a set of Style 135's square with an offset of 20. I am told by the seller that they came off a 2008 535Xi he traded in and that they will also fit a 2006 530XIT. I wanna pull the trigger on this wheel set but not sure if it will work on my car.Any advice or help would be greatly appreciated. Cheers. Ted
Old 04-04-2013, 05:06 AM
Ceenit's Avatar
My Ride: 525
Fairly confident that for the e60's, all xi (awd) models have an offset of 43, while all i (2wd) models have an offset of 20.
Methinks the seller may be mistaken.
I know from personal experience that you cannot put xi rims on a non-xi car (the fronts will press up against the strut tower and not spin). I have not personally tired the reverse (putting non-xi rims on an xi car), but I'm assuming there would some some type of fittment issue.
Old 04-04-2013, 06:16 AM
luigi524td's Avatar
Search for the xi Wheels/Rims posts. This topic has been discussed a lot. Actually most "high" offsets will work OK for an e60 xi. I ran 18" CSL reps with 35 offsets and 245/40x18" with no problem. In fact, shop carefully because some 3'er series wheels have high offsets that will work fine. Centerbores are another concern. Some wheels require hub adapters to fit properly.
See, there are lots of things to consider - not all wheels are created equally and not all sellers really really really know what they're talking about!!
Buyer beware.
Old 04-04-2013, 07:11 AM
Buyer beware.
This what I am thinking also. The seller being a BMWCCA member I would have thought he knew what he was saying but in all fairness to him he did tell me to check with BMW before I buy them.According to a tire fitment calculator the wheel will stick out 23MM more than stock which is too much for me especially on the fronts. Thanx to those who have read and offered advice. I knew I came to the right place to ask.Cheers. Ted
www.willtheyfit.com
All that said. Still looking for a set of Style 135's 18X8 square with an ET of 43.
Old 04-04-2013, 08:37 AM
depending on the dimensions of the wheel, the smallest offset we've put on an XI is in the low to mid 30s.
Old 04-08-2013, 09:49 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Didn't you say that you are currently running 135's? So are you looking for a second set?
Old 04-08-2013, 01:54 PM
Correct. My brother the previous owner swapped out his snow tires for three seasons on the original set therefore I am looking for another set of these rims for the summer. Ted
Old 04-09-2013, 11:11 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Default May I make a suggestion?
May I suggest that you perhaps stay within the same style but get a slightly different look for the main season?
M5-Style 166 replicas
Style 135 replicas
Although the 166's are listed as staggered, they'll sell them to you as a square setup. That's what I have.
The others are a little different, but still sharp looking.
OEMWheelsPlus is a good outfit and I'm very happy with the quality - going on two years now.
Old 04-09-2013, 11:54 AM
Giowizzy's Avatar
Style 135 replicas
I wonder how would they manage with NYC potholes???!!!!! For the price it's not bad at all. I'm feeling the Style 135 rep.
Old 04-09-2013, 02:18 PM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
OEMs don't manage well with potholes, so at least you're not out as much if you're running reps.
Quick Reply: 530Xi fitment
