19 Inch staggered: Which end counts?
My Ride: 535i XDrive M Sport Package
Model Year: 2011
I am considering Beyern Mesh 19's for my 2008 535i in a staggered set-up:
I.e. which speedo error will I get?
FRONT:
Wheel: 19x8.5 ET15
Tire: 245/35R19
Speedo error: 0.4%
REAR:
Wheel: 19x9.5 ET15
Tire: 275/30R19
Speedo error: 1.4%
Which end does the car use to compute speed? Wheel: 19x8.5 ET15
Tire: 245/35R19
Speedo error: 0.4%
REAR:
Wheel: 19x9.5 ET15
Tire: 275/30R19
Speedo error: 1.4%
the 9.5 reads speed.
if you like your rims in the back then run 265/35, 285/30 will protect more.
Keep rear sizes under 3%.
Also put your rear offset to 32,25,22...15 is really aggressive and will rub if you end up lowering. M5/6 are et19 I believe and flared fenders
A 275/30 is best for a 9 inch rim. Especially in the front
my 2 cents.
my 2 cents.
Model Year: 2011
my 2 cents.
my 2 cents.
Errowen
Its not the width, they rub due to the fact they sit under the fender lip from the aggressive offset
They should have a mesh wheel in a et30...then from there you can add spacers if need be.
BMW Wheels by Beyern - Mesh Design - BMW 7 Series Wheels, BMW 6 Series Wheels, BMW 5 Series and BMW 3 Series Wheels - BMW Custom Aftermarket Wheels from Beyern Wheels
ooo i like these...in a 9 front 10.5 rear!
BMW Wheels by Beyern - Bavaria Design - BMW 7 Series Wheels, BMW 6 Series Wheels, BMW 5 Series and BMW 3 Series Wheels - BMW Custom Aftermarket Wheels from Beyern Wheels
Model Year: 2011
timmay77
09-24-2015 09:38 AM
Bogdan7
09-23-2015 11:40 AM
