Strange Forum Formatting Issue
My Ride: 2008 BMW 550i
2006 BMW X3
Help!
For the last few days, I've had a strange problem trying to use e60.net. Any time I open a topic or look at recent posts, I see one message in full and the rest are shown with just the header. What's up with this? Did I change a setting accidently? I can't find anything to change it back
My Ride: F02 LCI Individual
Model Year: 2013
There is a box on the top right (just above your post) labeled "Options".
Click on it and select the Display Mode: "Switch to Standard", and everything is back to normal.
2006 BMW X3
Click on it and select "Standard", and everything is back to normal.![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
Model Year: 2013
Nothing changed, so you changed it accidentally.
I had this happen once and checked what exactly had happened. The problem was a link to another post in our forum. This link was opening a post in the outline display mode, probably because the poster was using this mode. Once you're on this mode, it is set...![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Something like that had probably happened to you too.
My Ride: G30 M550i
Model Year: 2018
In addition to Iceman's explanation, I've also found that this problem usually occurs after using the Google search box at the top of the page. It seems that Google often indexes pages in outline mode so if you are searching and you click one of the links that Google saved in that format, the board software will change your default to that mode until you change it back...
