HELP!!!can anyone please confirm the part number or a link to the correct bolt circled in blue and green in the other one I need to purchase thanks...and anything else I should consider BMW 525D E61 LCI 2008..thanks I'm in a desperate rush as I've already order the coilovers and not sure which bolt this is for the nsr thanks in advance
Thanks for your quick response to me much obliged would you agree that either of these kits or single bolts are correct based on your two part numbers thanks again
The bolt kits should be fine. Have to pay attention to the threads. On the original threads go all the way up. In the second pic, the threads are partially up the bolt. I don't know how much thread you will to get the torque spec. The camber nuts will work on the 9488 bolts
Thanks Sean 2 sets of these arrived and have the lipped angled groove I'm assuming these re right soon know when my son does it at the weekend thanks for your help
I've just ordered both axel repair kits as well as below for the sake of a few quid ill most likely use them at some point
