How do i retrofit from LCI Bi-xenon to Lci dynamic headlight on a E61 LCI?
Old 05-09-2024, 06:59 AM
This-Rex's Avatar
My Ride: E61 535D
Model Year: 2009
Engine: M57T2
Default How do i retrofit from LCI Bi-xenon to Lci dynamic headlight on a E61 LCI?
Hello, is there anyone who know how to retrofit from LCI Bi-xenon to Lci dynamic headlight on a E61 LCI?
I have installed the new headlights and LM2 AHL module. And coded it, but i get an adaptive headlight error and the curve lights don't work, but the rest of the lights work.
Do I need to do some rewiring or add more modules?
Old 05-15-2024, 05:34 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Did you wire up the adaptive part? non-adaptive cars don't have the proper wires running from the LM module to the headlight
Old 05-16-2024, 09:35 PM
DragoMPower's Avatar
My Ride: E60
First you need to make a wiring, there is alot of diagrams in internet, you will need to change the LM module too. Better is to find the LM2.C35 is best LM and latest module. You need the connectors from the LCI headlights and then cut of your connector and 30min wiring the new connectors. But first you must understand which cable for which is it. Look carefully, then you need to code with NCS Expert, to work properly. Good luck
sutt359
06-23-2021 01:25 PM
PrimeTimeTSA
09-09-2011 04:46 PM
Abbizle
12-08-2009 08:06 PM
ksa-sun
07-06-2009 11:56 AM
vishwen
11-15-2008 09:01 AM
Quick Reply: How do i retrofit from LCI Bi-xenon to Lci dynamic headlight on a E61 LCI?
