LIN bus error
Old 04-28-2024, 11:57 AM
BartvZessen's Avatar
My Ride: E60 Lci 530i
Engine: N53
Default LIN bus error
Hello everyone,
I have a strange fault code present: 9FF0 SZM: LIN comm. disrupted
i checked the fault code using ISTA and it wanted me to push the buttons and see it they go on.
when i press the button it activates, like the seat heating goes on etc, but it show the status ON on ISTA for like 1 refresh cycle and then changes back to OFF but in ISTA only, the seat heating remains physically on!
same goes for seat ventilation, but on the passenger side it only shows OFF, (but does work)
even stranger: it says the left block is the issue?!
any1 knows what i happening here? i have done nothing with the CCC besides placing a bluetooth adapter, but the code was already present before that.
Side note: i also have the code 9E60 residual heating field, seat cushion driver side, but i dont know what the problem is there and if its connected with the LIN bus error
Old 04-28-2024, 08:51 PM
donpb's Avatar
My Ride: '06 530i N52
So many different components can disrupt the Lin bus. It is not as simple as, oh, it's always this one thing. You are going to need to do some fault isolation (possibly a lot). If you do not possess the skills to DIY, I would suggest you have an electrical specialist diagnose the issue. Notice, I did not say have them repair it.
Old 04-29-2024, 12:13 AM
Engine: N53
im confident that i can DIY it, but i might needs some pointers in where to start. to my knowledge nothing has changed and it seems inpropable that the wiring or something got defective inside the dashboard as nothing has changed
Tigr
02-01-2022 03:45 AM
BartvZessen
06-16-2021 10:48 AM
knklhead
04-13-2017 12:26 PM
zimasha
04-02-2013 02:46 PM
inktoxicated
10-19-2010 03:30 PM
Quick Reply: LIN bus error
