Comfort Access Retrofit
Probation Members
My Ride: M5 LCI
Hello! I retrofitted my E60 M5 LCI comfort access. The cables are routed, the antennas are mounted, it is coded, but there is a delay when unlocking and locking (for 15 seconds it does not respond). A moment later it works fine then the same thing again. Is there a solution to this problem?
Can someone give me the exact locations of the antennas? Thanks
Probation Members
My Ride: E60 535d, nearly every option going!
Antenna locations:
> Under idrive unit
> Rear of centre console
> Parcel shelf
> Boot
> Rear Bumper
Did you also run the wire to the diversity antenna?
For me INPA says the antenna test is okay. Very confused!
denissm
06-11-2011 12:48 AM
