Passenger door control module
Old 01-07-2023, 02:38 AM
Acebell's Avatar
My Ride: 2005 BMW 525I
Default Passenger door control module
I have a 2005 525i production date is 01/2005. I recently install a passenger door module (which didn't have one but is required unless nothing would work in the door) after installing the window motor it just clicks & I get an anti trap function disabled error message on my idrive. Wondering do I need to program the module to my vehicle in order for the window to function properly? Also, what plugs into these two plugs on the module?
The lights work but when I go to let down or up the window only thing I hear is clicks. But all the other windows work. Could it be a bad module?
SOLVED: big s/o to @seanjordan20 with his help I had to program & code the module to get everything to work. Also, change system time & replace the window motor & them two plugs mentioned is for the mirror.
Old 01-07-2023, 03:28 PM
donpb's Avatar
My Ride: '06 530i N52
Old 01-07-2023, 03:49 PM
Acebell's Avatar
Originally Posted by donpb
got that but can't get the module to function because I see the car vin I got the module from is still attached to it. Trying to figure put a way to program my car's vin to it.
Old 01-07-2023, 04:14 PM
seanjordan20's Avatar
Oh man you bought used and don't know how to change the VIN. WINKFP is the program you're looking for. Program it, code it, then initialize it. Takes less than 5 mins to complete
Old 01-07-2023, 04:35 PM
Acebell's Avatar
first bmw so have no clue. Plus sounds simple if I got settings correct everything in their right folders etc.
Old 01-07-2023, 04:43 PM
donpb's Avatar
@seanjordan20 is the man for that.
Old 01-07-2023, 06:16 PM
Which module did you buy?
Old 01-07-2023, 06:28 PM
Acebell's Avatar
the passenger door module.
Old 01-07-2023, 06:38 PM
Do you have an airbag light on the speedometer. If so system time will have to be restarted also using Tool32. Of course if the module you changed looks like what's attached.
Old 01-07-2023, 06:42 PM
Acebell's Avatar
that's exactly what the module looks like & yes i do have the airbag light & seat belt light on. How do I "restart system time using Tool32"?
Quick Reply: Passenger door control module
