Recall Campaign Number: 22V-119: PCV Valve Heater
Old Apr 7, 2022 | 12:13 PM
militarydave's Avatar
My Ride: 09 BMW 528i - N52B30 Engine, 218k miles and counting. 2022 228i Gran Coupe. 18k miles and counting
Exclamation Recall Campaign Number: 22V-119: PCV Valve Heater
I received an official recall notice regarding the PCV Valve Heater for my E60 today. I guess they didn't fully fix the fire risk issues.
It states:
Why are we contacting you?:
"We are informing you of a safely recall on your vehicle, although we are not able to perform the remedy at this time. We will notify you with a follow-up letter as soon as we are able to perform this safety recall."
What Could Happen:
"The vehicle's PCV valve heater, which is only activated in cold weather climates, may not have been produced to specifications by the supplier. Over time, this could lead to overheating in the engine compartment. In some cases, it could lead to a fire." "If you see smoke from the engine compartment, or smell smoke, or a plastic burning odor, carefully move away from traffic and pull over to a safe location as soon as possible. All occupants should carefully exit the vehicle and more to a safe location away from traffic. Do not continue to drive the vehicle. Dial 911 in the event of an emergency or contact BMW Roadside Assistance to have your vehicle brought to the nearest authorized BMW center. BMW will reimburse you for the towing service if the issue is confirmed to be related to this recall.
What will BMW do?
The remedy is currently being developed. When the remedy is available, it will be performed free of charge.
I'm sure those affected will receive the notice, but just wanted to give everyone a heads up the "remedy is unavailable" at this time. I replaced my PCV hose when I replaced the starter and intake manifold gaskets, the actual PCV valve though I hear also breaks easily.
Hope they come up with a fix soon.
Old Apr 7, 2022 | 12:16 PM
I believe this only affects the N52 engine, but not sure.
Old Apr 7, 2022 | 12:35 PM
donpb's Avatar
My Ride: '06 530i N52
I have an N52, and they long since took care of mine. They might have just gotten to you. I have a friend with the same car as mine, and they recalled hers but not mine. I did not understand that at all. But then years later, they finally recalled mine.
I think they just didn't want everyone overloading the dealers then. My friend had to wait many months because of all the other people who got recalled. When I got my letter, they took care of me right away though.
Old Apr 7, 2022 | 01:39 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
No, this is a NEW recall for the same item. Mine was done a couple/three years ago as well and this is NEW. Apparently, the new part can still have an issue.
Old Apr 7, 2022 | 03:10 PM
donpb's Avatar
So, did you get the notice too?
Old Apr 7, 2022 | 03:48 PM
twh's Avatar
twh
Not yet, but I read the Recall when it came out recently and it applies.
Old Apr 7, 2022 | 05:50 PM
donpb's Avatar
I just read it (see attached file); I already since replaced that PCV valve heater when my hose cracked.
File Type: pdf
Old Apr 7, 2022 | 07:34 PM
twh's Avatar
twh
I know this is confusing. What the recall says is the two previous recalls on this matter are not adequate. In fact, the part that needs to exist to fix this does not yet exist.
The NTHSA Recall notice says "The remedy is currently being developed".
Q4. Did BMW conduct a similar Safety Recall?
Yes, in 2017 and 2019.
Q5. If I had a similar Safety Recall performed previously, will I need to have this Safety Recall
performed?
Yes. Your vehicle will need to have the 2022 Safety Recall performed.
Old Apr 7, 2022 | 10:09 PM
donpb's Avatar
I'm not sure who you are referring to, but I'm not confused.
Old Apr 7, 2022 | 10:46 PM
twh's Avatar
twh
If you think the recall doesn't apply to you, I believe you are mistaken.
