What is this plug from?
Old 12-17-2018, 07:13 PM
kd7iwp's Avatar
Engine: N54, M54
Default What is this plug from?
Tonight I took off the lower aluminum reinforcement plate under the front subframe for the first time and found this plug sitting on it. Anyone know where it goes? Looks like a plug for a drain hole or something. Also found a clip for the air filter box but that one was easy to take care of.
2009 535xi 6mt wagon.
Old 12-17-2018, 07:28 PM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Which aluminum plate? The stiffener plate under the subframe?
Old 12-17-2018, 07:29 PM
kd7iwp's Avatar
Engine: N54, M54
Yes. A previous owner would have dropped it and it fell on the aluminum plate under the engine. Took it off to change front differential fluid.
Old 12-21-2018, 02:07 PM
kd7iwp's Avatar
Engine: N54, M54
Bump. I guess no one has seen one of these before? I’ll try on an E90 forum in case it’s a part that’s N54 specific.
Old 12-21-2018, 03:32 PM
Sirius815's Avatar
My Ride: e61 535xi
It is on my automatic tranny by the flywheel. It allows access to the bolts that hold the torque converter to the flywheel. On a MT car I haven't seen this cover before, but it may be for the N54's MT.
Old 12-21-2018, 04:37 PM
kd7iwp's Avatar
Engine: N54, M54
Oh right, most cars have a plug on top of the flywheel to check if it is at TDC. I’ll look to see if that’s the case.
Old 12-22-2018, 01:33 AM
Sirius815's Avatar
My Ride: e61 535xi
No, not on top. Next to the oil pan, I think on the passenger side.
Old 12-22-2018, 06:14 AM
kd7iwp's Avatar
Engine: N54, M54
Oh, okay. I noticed an opening at the bottom of the bell housing where I could see the flywheel so that must be for TDC monitoring, but it was a square hole. I didn't look on the sides but next time it's up on ramps I'll check. Thank you.
Old 12-24-2018, 05:34 AM
gman6262's Avatar
My Ride: 2010 535xiT Touring, N54, Individual Audio
Engine: N54 3.0L Twin Turbo
The c shaped deflector on the plug is oriented towards the ground when you reinstall.
Old 12-26-2018, 05:45 PM
kd7iwp's Avatar
Engine: N54, M54
I looked up the par number and according to this diagram (part 9) it looks like you certainly are correct as it shows it next to the oil pan. Thanks.
Quick Reply: What is this plug from?
