2007 BMW 550 Vacuum Pump Question
Old 05-24-2018, 04:26 PM
3hHrToUr's Avatar
My Ride: 2007 550 Sport w/6 speed, upgraded Vossen 19in RIMs
Default 2007 BMW 550 Vacuum Pump Question
Hello just got my new Vacuum Pump from Pelican. Pulled the old one out... had oil in it, enough that when I turned the pump oil squrited out of the vent... is that normal?? I open the unit and it has oil still in it but not alott.. Iread oil is supposed to be in the pump... ok but was that to much and where is it coming from ?
the oil was motor oil? I am assuming the pump will self oil and i dont have to worry about adding any oil to lude it right ??
Also I have issues getting it in slot in the motor any tricks for that
thanks inadvance
Dan
Old 05-26-2018, 04:41 PM
Chris Mac's Avatar
My Ride: 550i sport package
I just replaced the seals (gaskets) in my vacuum pump a couple weeks ago. Did notice oil inside but didn’t try to spin pump so didn’t notice any coming out the vent.
To get the pump back on easy I used a 24mm socket and breaker bar to turn the crank slowly to line up the pump and slot inside the hole. Took some time to get it in but not bad.
I do recommend changing the oil pressure switch right below the vacuum pump at the same time. Way easier to do with vacuum pump off. Mine was leaking oil so I did them both.
gferr
05-29-2016 11:35 AM
Gibby550
04-01-2014 04:27 PM
05545i
01-08-2010 01:17 PM
05545i
DIY: Do It Yourself
01-07-2010 07:36 PM
tekygeek
10-12-2009 05:44 PM
Quick Reply: 2007 BMW 550 Vacuum Pump Question
