Inpa connection problems
Old 04-13-2018, 02:51 PM
joshmo144's Avatar
My Ride: 2005 bmw 545i
Exclamation Inpa connection problems
I just recently bought a k+dcan cable along with inpa and ncsexpert to code an aux cable. When loading up inpa both the little circles are white, the battery and ignition ones. Does anyone know how to get it to connect? I have been told some of these dcan cables are not pinned properly and that that may be causing the issue but I don’t know. Any help is appreciated!
Old 04-13-2018, 04:42 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
check to see if your cable has a switch on it to toggle between K-can and D-can.
Old 04-13-2018, 04:44 PM
joshmo144's Avatar
there is no switch
Old 04-14-2018, 06:42 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by joshmo144
there is no switch
I don't know how they're selling that cable as a K can and D can cable then.
BMWs produced on or before 2/2007 (like your 545i) need to have pins 7 and 8 bridged to work. later cars have pins 7 and 8 separated. the end of the cable should have small screws that allow you to remove the cover for the PCB. Take a look at it and see if pins 7 and 8 are bridged together or not. Where did you get this cable from?
Old 04-14-2018, 08:52 AM
joshmo144's Avatar
i ordered the cable from amazon. There are nine pins conning from the chip board to the obd connector. I don’t think 7and 8 are connected but it’s hard to see.
Old 04-16-2018, 12:13 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
I don't see 7 and 8 bridged. Try plugging it in with a small piece of copper wire connecting 7 and 8 together and see what happens.
Old 04-16-2018, 02:24 PM
joshmo144's Avatar
i connected 7 and 8 together and I have the same issue. Any other advice?
Old 04-16-2018, 05:12 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
I wonder if you don't have your edibas.ini file setup correctly, that'll do it too.
scroll down to post #13 in this thread. you'll need to know what com port your USB port is using
INPA Ini path ecu path and interface ?????
Old 04-16-2018, 05:54 PM
joshmo144's Avatar
yeah everything was in order i tried changing the com ports and the port the USB was in as well and it still didn’t change anything
mishka69
12-03-2014 09:33 AM
blinker528
05-15-2012 10:12 AM
mpc1971
Bluetooth & Cell Phone Forum
11-05-2010 09:36 AM
bmw1986
03-01-2007 08:52 PM
steck
DIY: Do It Yourself
10-02-2006 06:54 AM
Quick Reply: Inpa connection problems
