E39 Driving Lights
My Ride: 2000 540.. M sport Pkg, Dunlop SP9000, X3 3L.
E39 with M sport Pkg how do you get at the bulbs to change them. Manual shows without M pkg only and does not apply. Do you remove the black plastic grill or go up from the bottom by removing the bottom tray
i used to have a e39 and did all the bulbs changing myself
. i'm not sure about the sport package but i have to remove the black plastic grill in the front in order to take out the lens. once you have the lens out, everything is self-explanatory and very straight forward. let me know if you have hard time to remove the plastic grille. good luck
Thanks yes i had to romove the plastic grill and then it was obvious. I thought i could do without removing as manual does not mention that step.
Originally Posted by Alex Barnett' date='Sep 22 2004, 04:30 PM
Thanks yes i had to romove the plastic grill and then it was obvious.? I thought i could do without removing as manual does not mention that step.
[snapback]37186[/snapback]
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by alohalc' date='Sep 23 2004, 07:01 AM
seems like this forum is even better than the owner's manual
.[snapback]37217[/snapback]
