BMW M3 SMG
Old Dec 14, 2006 | 12:58 AM
damathis's Avatar
I just got a new M3 and my question is what are the optimal rpm to shift at because I am not used to driving a manual and I am a bit out of the loop. I drove an eclipse before this. I just want to know if I am babying my car too much because I normally shift into 3rd gear around 4000 rpms. Can someone explain the art of shifting in this BMW SMG that has a bit more experience than I do.
Old Dec 14, 2006 | 06:42 AM
vegastrashed's Avatar
Optimal shift point on a M model? Redline. Seriously.
Old Dec 14, 2006 | 06:52 AM
Fin535dA's Avatar
My Ride: –
Amen.
Old Dec 15, 2006 | 07:55 PM
0700700's Avatar
Old Dec 15, 2006 | 11:06 PM
Jeffs's Avatar
My Ride: 2003 X5 3.0----->gone 2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone 2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods... 2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
just wondering...are there shift lights too in a 6-spd M3 or only on SMG's?? And also abit offtopic but are there also shift lights on teh 545i/550 smg??
Old Dec 16, 2006 | 09:36 AM
0700700's Avatar
Only SMG afaik
Old Dec 19, 2006 | 09:23 PM
yamamoto's Avatar
I have an smg m3 and always shift it myself so I don't bump my head on the steering wheel when it decides to shift. The only time it is in auto mode is when my wife drives it (she hates it). You have to lift your foot (ever so slightly) at the same time you upshift the paddle. Also tap the gas on downshifts. This will help smooth things out.
john
Old Jan 1, 2007 | 03:53 PM
gIzzE's Avatar
My Ride: 530d Touring
I think alot of people worry too much about the SMG and the noises it makes, as John says, if you want to drive smoothly then keep it in S4 and lift of the gas a little as you change up and again when changing down, but you don't have to lift off at all you can stick it in S6, or maybe leave it is S5 while getting used to it, and just redline it, and change gear, don't need to lift off at all, it will make some noise at the rear but that is normal.
Just drive it like you stole it, that is what it is designed for.
Old Feb 18, 2007 | 01:49 AM
pinguhk's Avatar
My Ride: Mini Cooper
post on the 3er forum you will get more replys
socale39
Sep 5, 2023 08:30 AM
TroyE60
May 30, 2019 05:01 PM
JonathonK
Mar 27, 2015 08:13 AM
reckamech
Sep 8, 2003 01:24 PM
Aug 30, 2003 08:26 PM
