Off topic but need help
Old 06-26-2004, 09:17 PM
twinzor1's Avatar
Hopefully your fix WILL be as easy as running Spybot or Adaware, but often it's a bit more involved. If the problem persists, it is always a good idea to run a full virus scan. Then, look in your registry for homepage entries- start with HKEY_CURRENT_USERS\SOFTWARE\POLICIES\MICROSOFT\INT ERNET EXPLORER\CONTROL PANEL. If the entries RESET WEBSETTINGS or HOMEPAGE exist, validate the entries, delete them, save, and reboot. To echo the warnings of others', if you aren't accustomed to working with the registry, you may want to get help - you could do serious damage to your system.
If your page still resets on its own, or will not hold an initial homepage, 3rd party software is being loaded on startup, and you must prevent it from loading. You'll want to start by doing a clean boot of your system (simply starting up with a minimum of drivers/programs), support at Microsoft.com will tell you how based on your OS. Then, one by one, allow the programs to load until you've identified the culprit. Typically, you are looking for a rogue .hta, .js, or .vbs file.
Sorry, this is probably a bit more cursory than meaningful, but hopefully begins to point you in the right direction.
Old 06-28-2004, 09:37 PM
SFC_Miller's Avatar
Bunbun,
In addition to the above suggestions, you may try PCHELL.com. They offer easy step by step instructions to help you rid your system of spyware.
http://www.pchell.com/support/spyware.shtml
http://www.pchell.com/support/onlythebest.shtml
Old 06-29-2004, 01:18 AM
heezy545i's Avatar
Adaware should do the trick. After you fix things, just lay off the porn a bit.
Kasmo
07-08-2016 08:03 PM
BesE60
12
06-18-2015 08:51 AM
chrismanuel
05-10-2015 07:15 AM
thenewguy604
12-17-2004 08:13 AM
dwdrums00
12-16-2004 12:44 PM
Quick Reply: Off topic but need help
