Male or Female?
My Ride: Collected Sept 2009 - BMW E90 M3, Silverstone II, Novillo Black leather, 19" M Double-Spoke alloys, High Beam Assist, Electronic Damper Control, Voice Control, PDC, USB, DAB, High Gloss Shadowline, Sliding armrest, Trim Finishing in aluminium grey.
You might not have known this, but a lot of non-living objects are actually either male or female.
Here are some examples:
FREEZER BAGS: They are male, because they hold everything in, but you can see right through them.
PHOTOCOPIERS: These are female, because once turned off, it takes a while to warm them up again. They are an effective reproductive device if the right buttons are pushed, but can also wreak havoc if you push the wrong buttons.
TIRES: Tires are male, because they go bald easily and are often over inflated.
HOT AIR BALLOONS: Also a male object, because to get them to go
Anywhere, you have to light a fire under their arse.
SPONGES: These are female, because they are soft, squeezable and retain water.
WEB PAGES: Female, because they're constantly being looked at and frequently getting hit on.
TRAINS: Definitely male, because they always use the same old lines for picking up people.
EGG TIMERS: Egg timers are female because, over time, all the weight shifts to the bottom.
HAMMERS: Male, because in the last 5000 years, they've hardly changed at all, and are occasionally handy to have around.
THE REMOTE CONTROL: Female. Ha! You probably thought it would Be male, but consider this: It easily gives a man pleasure, he'd be lost without it, and while he doesn't always know which buttons to push, he just keeps tryin
