LCI CCC in a pre LCI E60
My Ride: BMW e60 525IA 12/2003
Hi All
Has anyone tryed to mount/re-fit the LCI-CCC in a pre LCI E60/61 ???
I have already the Nav. Prof. with the CCC for this , have got a 04/07 LCI CCC of E-bay , and would now like to mount/re-fit it in my pre LCI E60 , can see the Nav code is the same for both types ( SA609 ).
Until now I have been able to get the most functions coded and working on the LCI-CCC ( Logic7,TV.AUX,mp3,DAB,Telefon,Klima,HUD etc. ) thanks to the Ediabas NCS-Expert software , but the voice-control ( SA620 ) and the functions of the 8 bottons stil mis , do the bottons function have it's owne SA code ? anyone knows ?
Any help will much apriciated
Originally Posted by BenAnd' post='1020773' date='Sep 30 2009, 02:12 AM
Hi All
as far as the buttons, i don't have them, but i thought they were just preset buttons, so have you tried holding one down to store something to it, like you would the older radio station preset buttons?
Originally Posted by 545felix' post='1020926' date='Sep 30 2009, 03:57 PM
voice control is a separate item that has to be "unlocked" via an upload of a file. I don't know if the ediabas software can do that.
I know that about the voice code
No it is not pre-set botton's as we konw them from older radios, the problem is that thy worked when I first connected the CCC in the car , but after coding different options ( TV , HUD , Logic7 etc. ) the bottons stoped working.
I have found out that the function have it's owne code ( S6VAA ) , but the problem now is that the CAS modul do not accept this code in my 12/2003 E60 , so must find out if it is enough if I change the CAS-modul in order to get access to code the CIC modul.
So the "project" can show out to be more complex as I first did expect
Hi
Have got a lots of PM's on this issue , so please take a look here : https://5series.net/forums/index.php?showtopic=91175
me again
i have figured out myself, for someone with the same problem...
you must code CAPPL:
VA_FB
8_keys
VA_FB_AM_TOGGLE
aktiv
VA_FB_MODE_TOGGLE
aktiv
VA_FB_ENTERTAINMENT
aktiv
VA_FB_COMMUNICATION
aktiv
VA_FB_NAVIGATION
aktiv
and now the 8 fav buttons works
Someone knows a SA for this, so the automatic coding works?
VA_FB
8_keys
VA_FB_AM_TOGGLE
aktiv
VA_FB_MODE_TOGGLE
aktiv
VA_FB_ENTERTAINMENT
aktiv
VA_FB_COMMUNICATION
aktiv
VA_FB_NAVIGATION
aktiv
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi mate did you get your 8 buttons fully working if so how was it the above coding options?
