HUD retrofit - Parts list
Old Jan 17, 2009 | 04:08 AM
AlexFW's Avatar
Default HUD retrofit - Parts list
Okay members, -thank to BenAnd!!- now we have the complete list of parts we need:
HUD Unit (I have here 62 30 9 154 603, for left hand drive cars, up to 5/2007)
(prices vary from EUR 60 to 4-500 on eBay)
HUD Windshield
Hud dashboard or cutting your non HUD dashboard
62306934584 (If you have black dashboard - /6 for grey)
62306936221 (trimming)
61316925289 (Xenon + HUD lights control) or 6131 6 946 339 if you want also night vision.
61359120310 (hud light/rain sensor)
61136906535 (LVDS connector)
61120142318 (LVDS cable, 7 metres grin.gif)
2 x 6113 6 901 847 ( male end-connector for LVDS cable )
2 x 6113 6 901 846 ( female end-connector for LVDS cable )
1 x 6113 8 387 214 ( LVDS cable housing at the connector at the HUD )
1 x 6113 8 384 550 ( 12 pin connector at the HUD )
20 x 6113 1 393 704 ( wire pin's for the connector at the HUD and the light switc , you need 14 , but then you have some to "loose" ).
(about EUR 300 in Europe)
A brave man
10 hours
Good luck!
(Pls Ben correct me if I'm wrong)
And now?
I think dealers must have guides/instructions to replace the unit in case of failure. (+ we need PDF to unmount the dashboard)
Old Jan 17, 2009 | 04:47 AM
vekkuli's Avatar
Are you sure, you don't need new LM?
Light module
Old Jan 17, 2009 | 05:34 AM
AlexFW's Avatar
Light module
BenAnd said no, because a friend of him did it without changing the LM. And it works.
Which is your experience? Pls share with us!
Old Jan 17, 2009 | 06:08 AM
vekkuli's Avatar
OK, nice to know...
I just need new rain/ light sensor and then programing FA-list. But who can do this programing???
Old Jan 17, 2009 | 06:49 AM
AlexFW's Avatar
Originally Posted by vekkuli' post='770184' date='Jan 17 2009, 04:08 PM
OK, nice to know...
It's like my heated steering wheel: just ask your FA-list to your dealer, use and XML editor and add "<option>610</option>" in it.
Then save the file and load it on the car (you have to have the latest Progman) by dealer's computers.
I will confirm the procedure in some days - I hope.
It's pretty simple, if you know what are you doing
PS:
I thought you already had the HUD
Old Jan 17, 2009 | 11:27 AM
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi Alex
Fine list you have made , it look's Okay to me , it's right you don't have to change your LM ( Light Modul ) when mounting HUD , only rain/light sensor have to be changed ( and light-control switc ).
Here just a pitcure of my latetes mode , build I-drive controller in the arm-rest at the rear seat , have just to hook it up now , and then I'm also the "boss" when sitting in the rearseat .
Old Jan 17, 2009 | 11:38 AM
AlexFW's Avatar
Originally Posted by BenAnd' post='770348' date='Jan 17 2009, 09:27 PM
Hi Alex
Do you remember how you proceeded?
Would you be able to write some lines to explain what to do once removed the dashboard?
ROTFL Ben, you are absurd! Completely mad
Old Jan 17, 2009 | 12:18 PM
BenAnd's Avatar
Hi Alex
when the dashboard first is out , it's quit easy , put in the 2 blind nite's , stick the holder a-round the pipe , now put in/down the HUD unit , screew it in with the 2 6mm bolt's and the 8mm , now re-fit the dashboard , all wirering to the HUD can be made from underneath the dashboard/steeringwheel afterworths.
Please see pic's
Attached Thumbnails HUD retrofit - Parts list-100_0159b.jpg   HUD retrofit - Parts list-100_0163b.jpg   HUD retrofit - Parts list-100_0174b.jpg   HUD retrofit - Parts list-100_0176b.jpg
Old Jan 17, 2009 | 12:36 PM
AlexFW's Avatar
Ben, are you able to provide a list of all little parts?
As that 07147121926. When you order this kind of part it has to arrive from Germany (except USA I think). And we need to have everything on the table when we start
Old Jan 17, 2009 | 12:41 PM
BenAnd's Avatar
Hi Alex
I have allready posted it in another thread , but here you have them again.
Attached Thumbnails HUD retrofit - Parts list-1.jpg   HUD retrofit - Parts list-2.jpg
