Coolant temp gauge!!
I have read some posts on this and some you the folks here on the forum have mentioned that the white lines in the Tach might work as the temp gauge.
I have tried to notice that but mine doesn't move at all.
I remember test driving a 2007 550 where I did see those lines come up after I started the car. But it does not happen in my car.
Are they useful at all? and what could be the reason for mine not doing anything.
Thanks in advance.
Thanks in advance.
My Ride: 2004 545i 6spd Man, 19' Breyton Wheels, Ipod Install, Parrot Bluetooth, AC roof and Trunk Spoiler
Thanks in advance.
Thanks in advance.
I've always felt that it wouldn't be wise to use the variable warning (white lines) on the tachometer as any reliable temperature gauge. Sure, they'll help tell you when the engine is warmed up (and safe to rev higher) but I don't think it's very safe to equate these lines with coolant temperature.
Don't forget that once the lines hit the end of their travel, that doesn't mean the engine is at full operating temperature (or higher.) Also, since the LCI, they've stopped moving so it seems to me as if they may not have even served much of an important purpose. If they did serve a purpose, it's likely that BMW wouldn't have eliminated that functionality...
Thanks Rudy for the information. So that is what I saw when I drove the 07. Since mine don't move at all.
Originally Posted by s4iscool' post='513034' date='Jan 2 2008, 09:47 PM
they were a bit of eye candy that I remember first seeing on the E39 M5. I would think BMW stopped it to cut costs, end of story.
On the M-cars, the tachometer has LED's that change from amber to red, indicating not just a warning band but also a variable redline. I've never tested one but I believe that on the M-cars, the variable redline actually included a variable rev-limiter so you could never exceed whatever the redline was currently indicating.
(M guys please correct me if that's not accurate...)
My Ride: 2007 530Xi - Navigation, Premium package, Steptronic.
Originally Posted by Rudy' post='513037' date='Jan 2 2008, 09:51 PM
The variable tachometer redline on the M cars is not the same as what the non-M, pre-LCI E60 has. On the non-M cars, the white bars were variable but it was simply a warning band that did not stop the driver from exceeding the warning.
My 530xi has the moveable white lines in the tach. On a cold day, at start, they're hanging at 5500. Eventually they get up to 6800. I think they're pretty-much useless (and apparently BMW agrees). I'd like to have a real oil-temperature gauge in my E60. I'd like to have a dipstick too. Not likely that will ever happen again...
My Ride: 2008 BMW 550i Sport
Carbon Black Metallic/Cream Beige
Manny tranny and other stuff
Recently gone, but never forgotten:
2005 Ford Mustang GT (hence the name)
Torch Red/Crimson
Manny tranny and every option available for that year
2002 Chrysler 300M Special
Brilliant Black/Light Taupe/Dark Slate
Autostick and goo-gobs of neat features that I will sorely miss
Correct. The guage has/had nothing to do with the coolant temp. If anything, it was more of a viscosity guage and it varied not only with the engine oil temp but also with the ambient air temp.
My Ride: 2005 545i with Sport Pkg, Nav, HUD, Cold Weather Pkg, Rear Shades
Pg 65 from the '05 545i Manual:
Tachometer
The white-striped advance warning field,
arrow 1, changes depending on the engine
temperature. The segments disappear in
sequence as the engine warms to its normal
operating temperature. Avoid allowing the
engine speed to rise as far as the orange warning
sector whenever possible.
Engine speeds in the red warning field, arrow 2,
must absolutely be avoided. In this range, the
fuel supply is interrupted to protect the engine.
Tachometer
Engine: 545i
On my M5 cluster the oil temp gauge takes way longer to indicate a rise in temp after the temp dial has reached it's nadir on the cluster (indicating coolant level) meaning as mentioned before : you shouldn't floor it just yet.
The oil temp on the M5 cluster has given me a new perspective on when the engine is really ready to be revved high.
