LCI Retrofit Facelift Lights
Old Nov 5, 2007 | 06:27 PM
RootKit's Avatar
The LCI retrofit is a retrofit cable set for the facelift lights. This is the BMW OEM solution to get the facelift headlights and taillights working on pre-LCI cars. A new light module (LM) needs to be installed on cars before 09/06.
Part numbers:
E60: 61 12 0 432 110
E61: 61 12 0 432 397
The cable kit consists of many parts (adapters, sockets, etc.). A person would have to buy the facelift headlights, taillights and light module separately.
The TIS document states an approximately 5.5 hours. But I would think it is much longer for older cars or when troubleshooting arise. It sounds like a 2 days labor extensive dealer job! For the taillights, couple of the wires from the cables need to be routed all the way to the front of the car--connecting the pins directly to the dismantled plug on the LM. The headlights require bumper removal. The pre-LCI existing plugs (the 8-pin plug and 4-pin plug) have to be completely disassembled. A provided 12-pin socket will then be individually wired and this plugs into the facelift headlight. And finally the car is program/encoded.
Old Nov 5, 2007 | 07:31 PM
KnIgHtCoM's Avatar
Do you know how much for all the hardware and estimated labor costs for the install?
Old Nov 5, 2007 | 08:16 PM
bmw_wpq31's Avatar
My Ride: MY2005 E60 525i M Sports
Rootkit, how much does it cost for the whole retrofit kit cables & LM? (excluding headlights & tail lights)...
Old Nov 5, 2007 | 10:00 PM
RootKit's Avatar
The approx. price breakdown...
a. AHL-xenon headlights: 1,850
b. Taillights: 430
c. Light module: 350
d. Retrofit cable set: 50
e. "Labor": 1,000
Give or take, somewhere between $3.5k to $4k out the door.
Old Nov 6, 2007 | 05:55 AM
coolguy's Avatar
My Ride: 2006 525i, Premium,Cold,Xenon Packages
So Rear Tailight = $430 + $50 cable?
Old Nov 6, 2007 | 06:03 AM
5er Sport's Avatar
I think you will also need the light module but I'm not sure.
Old Nov 6, 2007 | 06:19 AM
RootKit's Avatar
Yes, new light module if your car is older than 09/06. In addition to that, programming.
Old Nov 6, 2007 | 06:20 AM
coolguy's Avatar
I thought the light module is only for LCI front headlights right? LCI Rear only needs a retrofit cable isnt it.
Old Nov 6, 2007 | 06:26 AM
RootKit's Avatar
The light module controls both front headlights and the rear taillights. the rear needs a retrofit cable adapter and then there is some long wires that hooks to LM to the front. Programming is necessary to get correct function or fix errors.
Old Nov 6, 2007 | 06:27 AM
nigxdoof's Avatar
4-5k for lights... I think we all would agree that you can do a lot more with 4-5k, than just lights. =)
Get some 20 inch rims! or.. bodykit, and rims and springs. heh.
So much. or just keep the car the same and get a motorcycle, Used of course. If you want speed that is.
If is cool that BMW offer's the retrofit cables and such, but its just so expensive.
MK
