5Series.net - Forums
-   Group Buys (https://5series.net/forums/group-buys-28/)
-   -   Retrofit cable for LCI look on Aftermarket Sonar lights (https://5series.net/forums/group-buys-28/retrofit-cable-lci-look-aftermarket-sonar-lights-113795/)
bruce_miranda May 31, 2011 02:27 PM
I was playing with some configuration and coding settings and I've created a completely passive retrofit cable for the Aftermarket Sonar lights. As seen here https://5series.net/forums/topic/904...y-tail-lights/
It fixes ALL the drawbacks that the original lights had. But most importantly they are half the price of my electronic based cables.
1. You get both Brake lights to come on only when you Brake.
2. The LED rods are brighter.
3. You dont need the resistor boxes, so no more heat.
Ofcourse the cable is all plug and play and uses original BMW plugs.
You MUST have a working NCSexpert set-up but I will provide the NCSExpert values to change as well on your car.
If I have 5 people interested in this, then I can do the cables for £75 each.
This works with both LM1 and LM2 modules.
rctmthouse May 31, 2011 07:11 PM
Bruce, can you elaborate more on this? I'm interested but not sure what this mean. Still a newbie when it comes to the E60, electronic wise.
Thanks
bruce_miranda Jun 1, 2011 01:07 AM
This cable is for people who bought the Aftermarket non OEM Sonar LCI-Look tail-lights but have been disappointed because they didn't look good when installed on the car. This is due to the false marketing by the sellers of this product that make it seem like you'll get the LCI look at a fraction of the cost.
The problem is that this product is flawed and probably a tad unsafe as well.
In the past I have produced and sold a cableset that solved the problems with the product, to the extent possible. However the sheer UK based production costs of the kit make it expensive and that has put people off this, especially since the lights are so cheap.
Seeing that so many people are into coding their own cars using NCSExpert, I decided to make a version of the cable that is cheap to produce but will need the car coded.
The cable itself is completely PnP and there is no cutting involved, the process is completely reversible.
Another advantage of this solution is that should, in the future, you decide to upgrade to the actual OEM LCI light the coding is the same and you will just need to swap a plug on one end of the cable.
BUT remember, you MUST have a working NCSexpert set-up to do this. Please don't ask me questions on this because I will assume you know what you are doing. However I will supply you with the NCSExpert settings required.
rctmthouse Jun 1, 2011 09:56 AM
Ah...got it. Thanks Bruce. Will need to look into this coding down the line; looks a bit complicated for me though.
bmwfive Jun 16, 2011 04:40 AM
Will you be making a version of this cable with the LCI plugs already attached? (for those who use NCSExpert)
bruce_miranda Jun 29, 2011 01:35 PM
Hopefully now that there is a review of these cables there will be more interest. Honestly this is best upgrade you can do to the Sonar lights. It drives them at their maximum potential. After this, if you want better then OEM is the only way.
https://5series.net/forums/topic/114..._fromsearch__1
Also, if there is anyone in the UK who is interested, I can do a set of Brand new lights and cables + coding for £300 total. Just one set of lights available - bought these to test the cables and they have never been mounted on the car yet.
Farooq Sep 17, 2011 01:42 PM
sorry to bring this old thread alive again ,, Bruce : is this cable also works on the original LCI or only on the aftermarket LCI ,, I have 530I 2004 , I'm interested in changing my ugly taillights ..
the problem is I bought the original LCI and I bought the retrofit kit from BMW ,, but after reading several threads here , i found out that I can't just swap the taillights ,, I have to make full LCI upgrade with headlights and light module ..
I wanted to PM you but I still don't have enough post ...
thanks in advance .
bruce_miranda Sep 18, 2011 01:12 AM
So you want to do the rears only, why not buy my plug and play cable? Its the easiest way to get the rears done with least hassle. If you want to reuse the parts you have bought already its going to involve coding. Contact me and I'll help you either way. You should be able to PM now.
Farooq Sep 18, 2011 03:29 AM
great , we will talk in PM .. :thumbsup:
