CKS coilover for E60 Xi
Hey just wanna see if anyone else installed their coils ?? I had mine installed and my fronts are not going down. There stuck at almost factory height. Just spoke to John he said no one else has contacted him yet. Just curious if anyone else is having the same issue??
Yea the shock collar is stuck. John is getting me new parts and sending them to me. Also just a heads up your gonna need spacers for the front because the stock wheels rub against the coil overs. I bought 10mm and is good now.
1) By "stock", you are referring to 17x7.5 et43, correct?
2) How much of rubbing did you have with coilover?
3) Was 10mm spacer the minimum clearance you had to have to clear coilover or did you select 10mm since it is a hub-centric? Meaning, what was the absolute minimum clearance you had to have?
4) With 10mm spacer, how flush are you with fender?
I have 19x8.5 et43 summer wheel/tire, so I knew I was to get 10mm spacer at least based on stock vs aftermarket wheel spec. But with your info on rubbing with stock wheel, I might need to reconsider my spacer and/or wheel spec again :\
My Ride: 2008 BMW 535 xi M sport.
2012 BMW 535 Xdrive M sport
2007 Toyota Sienna FWD LE
1996 Toyota 4runner Limited
R.I.P.
2003 BMW 745Li, fully loaded
2001 BMW X5 3.0, Premium pck
1997 Chrysler Town & Country AWD
1998 Mercedes S320
1995 Mercedes 560 SEL
I installed mine but its not low enough, looks almost like factory sport height, so I am going back for adjustment I will let u guys know if mine starts rubbing.
I am currently running on 19x8.5 as well.
I notice the ride being a bit bumpy and harsh, do you guys feel that?
I never sat inside a KW V3 before, but I have on a V2 335xi, it feels much more balance.
Great news, and thanks for the spacer info! I have few questions:
2) very little rubbing with the coil over
3) i could have gotten away with a 5mm but they didnt have any in stock.
4) not really that flush
I think the 10mm with be fine for your summer set up
I only drove the car from the shop to my house but yea it was harder then I expected it to be. I'm gonna play with the dampening and hope it gets smoother.
My boy has the KW V3 in his 5 series and it rides just like stock at any height.
Are you running any spacers with your current setup? What is your wheel offset?
