Frequently Asked Questions Feel free to add to our FAQ answers or contribute new questions.
Techron Fuel Injector Cleaner / Oil Change
Old 04-10-2016, 04:58 AM
elkk's Avatar
My Ride: 2008 535i
Default Techron Fuel Injector Cleaner / Oil Change
I was recently told at a club meeting that it is necessary to change oil immediately after using Techron Fuel Injector Cleaner in the gas tank....huh? Anyone head of doing this and why? Thank.
Old 04-10-2016, 06:42 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
The theory is that Techron is a fuel detergent, and it will cause a little bit of fuel contamination with the oil causing the oil to be contaminated with fuel. I used to use Techron in my E30, and I would always time my Techron use with an upcoming oil change. If you are due for an oil change then your concerns are moot; if you just changed your oil, I wouldn't worry about it.
cheers.
tnixa
04-09-2016 02:28 PM
MiniNL
04-07-2016 06:35 PM
blackedout545i
04-05-2016 04:58 PM
Sonny007
04-04-2016 02:50 AM
Nikola Lefterov
03-28-2016 07:52 AM
Quick Reply: Techron Fuel Injector Cleaner / Oil Change
