Techron Fuel Injector Cleaner / Oil Change
My Ride: 2008 535i
I was recently told at a club meeting that it is necessary to change oil immediately after using Techron Fuel Injector Cleaner in the gas tank....huh? Anyone head of doing this and why? Thank.
My Ride: 530i
Engine: M54
The theory is that Techron is a fuel detergent, and it will cause a little bit of fuel contamination with the oil causing the oil to be contaminated with fuel. I used to use Techron in my E30, and I would always time my Techron use with an upcoming oil change. If you are due for an oil change then your concerns are moot; if you just changed your oil, I wouldn't worry about it.
cheers.
cheers.
