Frequently Asked Questions Feel free to add to our FAQ answers or contribute new questions.
How does the Head-Up Display (HUD) work?
Old 01-23-2008, 05:24 PM
  #21
shahril78's Avatar
My Ride: E60 525i
hi guys, need to check with you, my car doesn't come with the HUD. it is a 2004 model. was wondering from which year does this HUD was fitted? i've read in this forum that the cost to install the HUD unit is costly - rite?
Old 01-23-2008, 05:27 PM
  #22
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
HUD was offered in 2004 but I think it was around February 2004 production. If your car doesn't have it, it's probably cheaper to find a car that has one than try to retrofit it into your car...
Old 01-23-2008, 05:58 PM
  #23
shahril78's Avatar
My Ride: E60 525i
Hi Rudy,
thanks for the reply. but i've read in the forum said that it requires extra works such as getting a new dashboard?
Old 01-23-2008, 06:40 PM
  #24
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by shahril78' post='522084' date='Jan 23 2008, 09:58 PM
Hi Rudy,
New dashboard, new windshield, etc.
Old 01-23-2008, 07:02 PM
  #25
shahril78's Avatar
My Ride: E60 525i
well, for my case, no point. just enjoy what i had at the moment then.
Old 10-07-2008, 10:18 AM
  #26
djxilo's Avatar
Has anyone had luck adjusting the height of the HUD? Is this a DIY project or would I need to take it to the dealership?
Old 12-11-2008, 12:41 AM
  #27
BenAnd's Avatar
My Ride: BMW e60 525IA 12/2003
Hi
Re-fit a HUD can be done , cost about 700-1000USD , an a lot of work
New dashboard is not nessesery , you can use the one you have , must just be altered. ( make hole for the HUD lens + HUD frame )
It will also work with your ordenaiery windshield ( you must have a wery good sight to see the difference , I changed first my windshield later to the right one ,due to a "crack" in the old windshield ), so long it is not a "klima comfort windshield" , you can't have this together with HUD according to BMW.
If any one will , I can upload some pitcure from the "project" , so you can see what you up against It was one of my "bigger" task's
Old 12-21-2008, 05:02 AM
  #28
BenAnd's Avatar
Hi
As promised here some photo's from the HUD re-fit , it toke some time to do
Old 12-21-2008, 05:07 AM
  #29
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Did you get everything back together and functioning yet? Did you end up keeping the "normal" windshield or did you get the HUD windshield? (With the normal windshield, the HUD image may be double...)
Outstanding work BenAnd!
Old 12-21-2008, 05:17 AM
  #30
BenAnd's Avatar
Hi Rudy
Thanks
Yes I got it all "together" again , but it toke me the most of 8 hours from start to finish , and after changing the ligt/rain sensor + coding the car for HUD ,it now works 100%
First I drove with the "ordenary" windshield , but now I have the HUD windshield ( changed becurse of a crack in the windshield this sommer ) , but I will say , "yes" you can see the difference between a "not" HUD windshield and "a" HUD windshield , BUT you can easyly drive with a "not" HUD windshield after re-fitting a HUD , the difference is , as I see it very small , only something you notic if you look very carefull for it.
Quick Reply: How does the Head-Up Display (HUD) work?
