Xenon HID headlight assembly options
My Ride: 2013 550i xDrive M Sport
Model Year: 2013
2013 550i xDrive with xenon HID- I have to replace the driver side heat light assembly due to a crack and moisture getting in and causing Turn signal malfunctions. Used is $1k!! What other options should I be considering? Reman/aftermarket?
You could remove the cover and replace, but that's a lot of work + cost. If you buy Genuine, that would be $1,200 but you can also use Hella for a lot less.
530ddriver
DIY: Do It Yourself
08-03-2008 04:21 AM
subterFUSE
03-22-2005 05:13 PM
