xi wheel offsets
Administrator
Are the xi wheel offsets for the F10 and the E60 cars the same? I'm curious in case a style I happen to like on an F10 xi will also fit my '07.
You should be able to find out from here = http://realoem.com/b...body=tou&arch=0 ... in detail. GL!
F10 x - 18*8 et 30
E60 x - 18*8 et 43
E60 x - 18*8 et 43
Administrator
Thanks. It doesn't look like it. Funny, for the E60, it's called "xi". For the F10, it's "ix". I'm assuming both mean the AWD version.
Just FYI: ET30 with up to 8.5" wide rims will fit on E60 Xi.
I checked just about all the wheel packages that realoem.com lists for F10 550iX - they will all fit. Even might require spacers in the back on some; ET44 on a 9" wide is kind of "shallow". ET32 on 9.5" wides in the back is flush, so ET44 on a 9" will sit ~20-25mm's deeper in the wheel well.
Tires, on the other hand, are taller (higher sidewalls) on F10's, so you'd still need to get different ones to use on an E60.
Administrator
asinner
05-06-2015 06:03 PM
