F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
Winter wheels and tires for 550i
Old 09-04-2010, 09:23 AM
Wallie_17's Avatar
Thanks for the help everyone!
My father's salesman in Montreal says its going to cost $4,000.00 + tax for a complete set. For that kind of money I can choose my own wheels and tires from Tirerack, but he is convinced That BMW OEM parts are superior quality than BBS wheels (The ones I chose from the Tirerack).
Who does manufacture BMW wheels?
Old 09-04-2010, 10:13 AM
DrLev99's Avatar
I wouldn't waste that kind of money on winter rims and tires, esp, 18" or 17" ones.
Old 09-04-2010, 10:30 AM
tadtaggert's Avatar
+1
No need to spend even half that.
Old 09-04-2010, 11:11 AM
luigi524td's Avatar
Actually, BBS is the manufacturer of many BMW Original Equipment Wheels ... for sure there are lots of manufacturers of automotive wheels. They run the gamut from very very good (even some that exceed "original" BMW quality) to the other end of the spectrum.
Don't let "price" alone lure your Father into thinking that more expensive is "better". However, if he insists that is the truth, please send me his phone number - I have water-front property I'd like to sell him!
Old 09-06-2010, 08:38 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Petes550i
Isn't kind of early to start shopping for snow tires?
Maybe not if you live in Alaska.
It's really not too early to be thinking about this. Often times, places like the Tire Rack will run out of stock on some of the tire sizes needed for our cars.
DrLev99 has the same winter setup as I do (from the E60) so the big question right now is...will they fit/work on the F10?
Ricracing's Avatar
That's ok...these are ET20 and could use a big bump out on the E60. I am guessing they'll fit. I still have a year to worry about it. Bah!
I doubt it.
F10 19" and 20" wheels standard ET's are 33 front (8.5") and 44 rear (9").
Tires 245/275.
ET for the standard F10 18" wheels is 30 and the tires 245/45 18".
The 17" wheels are way too small for the F10.
Old 09-11-2010, 10:15 PM
jlgjwu's Avatar
My Ride: '11 535i Space Grey Met. w/ Blk Dakota Leather, Executive Package, M-Sport Package, Dynamic Handling Package, 35% tint '06 525i Titanium Silver (retired) Premium pkg, PDC, Logic 7, adaptive headlights std. items - xenons, cold weather pkg mods so far - red euro reflectors, UGDO & compass rearview mirror, 35% tint, H&R Sport Springs, 18" style 124 OEM rims
Originally Posted by Ricracing
I doubt it.
Tires 245/275.
I'm not so sure on that.....
The reason why is that the style 327 stock rims on the 528i are 17" rims. The circumference of the 17" rim with P225/55R17 stock tires is 84" (2133.6mm) The circumference of the P245/45R18 tires (stock size for 535i non sport) is 83.81" (2128.7mm). The circumference of the P245/40R19 (535i sport) is 83.91" (2131.3mm) with a rear tire P275/35R19 circumference of 83.47" (2120.1mm).
All the tire sizes found on the 528i, 535i & 550i in North America are within tolerance of the stock 17" size which is probably what the speedo is calibrated to.
Based on this and the fact that it would be a waste to spend big $$ on a set of winter rims, I really hope that the ET20 offset E60 rims will fit the F10. There's only a 10mm diff between the offsets of the E60 and F10 stock rims. The way I figure is that the E60 rims, even with it being a bit narrower, has got to look better than a set of steel rims.
I'm not too worried on what the winter rims look like as they'll be exposed to salt and all sorts of crap. As such, the old E60 rims would be perfect as I don't have to protect them.
I've ordered my F10 535i with sport and am really hoping that my E60 rims will fit. It'll save me a bundle as I only have to buy snowies and not rims. If anyone has tried / knows for certain if the E60 rims will fit, please post your results.
Thanks
Old 09-12-2010, 06:28 AM
pharding's Avatar
My Ride: 11 550i Sophisto Gray/Oyster Black/Anthracite, Sprt Trns, DHP, IAS, SP, PP1, PP2, CWP, HUD, DAP, AVSP, SF RS, CA, ACC - Euro Del
Is this the F10 section??!! Bah...wonder if these wheels above fit? I am still guessing yes.
No they will not fit the F10.
Old 09-12-2010, 07:08 AM
Petes550i's Avatar
My Ride: 2011 BMW 550i; Dark Graphite Metalliic/Oyster, 4.4 TT V8, 8-sp AT, Sports Package, Dynamic Handling, Premium Package 2, Cold Weather Package, HUD
Just get some cheap winter rims from Tire Rack....that's what I'm planning to do when I get my snow tires.
Old 09-13-2010, 11:34 PM
DrLev99's Avatar
I doubt it.
Tires 245/275.
I disagree. If you take what's been clearly established with the E60 max offsets for optimal push outward, I could still put 14mm spacers on my 8" ET20 rims up front without rubbing (OEM offsets for 18x8 rims), and in back I could push them out at least 25mm more with same size 245 8" rear, without rubbing. I use my 12mm spacers now in back and the 8" winter rims are still pushed way in with this winter setup, proving my point.
If the "true" max outward ET push for the F10 is anything like the true E60, then these ET20 8" rims should still fit the F10 nicely.
Quick Reply: Winter wheels and tires for 550i
