F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
Where is the OIL TEMP sensor located on 2011 528i??
Old Dec 15, 2021 | 06:15 PM
Donaldj79's Avatar
My Ride: 2011 528i with NAV
Default Where is the OIL TEMP sensor located on 2011 528i??
Been battling with several codes on this car. I have changed the Coolant Temp sensor up front. Not sure where the Oil Temp sensor is located? I've seen some say under the intake manifold? A diagram or picture with an arrow would be a great help.
Car cuts off and goes into neutral. EVERY time that happens...Oil Temp needle fluctuates significantly. Also takes 15-20 mins (or more) of driving, before the needle moves to operating temp.
Old Dec 16, 2021 | 05:04 PM
donpb's Avatar
My Ride: '06 530i N52
Go to, RealOEM.com - Select Your BMW Model, search for coolant temperature sensor.
grantbp
F10 Discussion
Oct 12, 2018 06:52 PM
kskane
Feb 29, 2016 04:28 PM
mwaku
Nov 2, 2014 09:51 AM
best1
Oct 4, 2011 05:56 PM
superconfort
Apr 1, 2009 12:16 AM
