Rigth side door handles Malfunction
Last year I had a problem with a cigarett lighter socket so I went to an official customer service center near my home.
Next day, my right side rear door lock starts open and lock repeatedly around ten times when I go close to a gas tank.
I went back to the center and they said they just changed the fuse of cigarett lighter and it is not their fault.
Anyhow I came back and I did not go to the gas tank with my key, funny huh.
It was tired with the malfuntion and I went back last winter and the engineer said there is malfuntion with right side door handles.
He said it takes more than 1k$ each and just drive it.
A month ago battery drain signal showed up every day and I changed the battery.
The guys who changed the battery has a scanner and it said right side door handle malfuntions.
What should I do?
Do I need to ask the center guys to check all the fuses or replace the door handles?
I think even I change the parts that doen't solve the problem.
So Stressed.
What should I do?
So Stressed.
I think the guys in the service center think not only handle problem but also locking system should be changed. Also, receiving the parts takes a lot of time from Germany cuz I live in South Korea. I really do not want to be ripped off. I found some thread says taking out the fuse worked so I will try it.
For both handles to go out at the same time, I highly doubt that is factual unless you have a lot of bad luck. You can start pulling fuses to isolate. Can I assume that you have comfort access?
Guys, the mechanic in the service center pulled out of the CA cables and the problem dissapeared. I cannot use comfort access on the right side of doors but LED lights is working and no more stress from the battery drain. Thank you all.
