F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
Question about F10 OEM wheels?
Old 09-20-2010, 02:32 AM
Alex-F10's Avatar
Who knows parametres of OEM 17" wheels (design 236)?
I know that it is 8JX17 ET:30, but who knows DIA and PCD?
Old 09-20-2010, 03:18 AM
v_therussian's Avatar
?? realoem.com ?? ???????? ??????? ??? ?????? ????
Old 09-20-2010, 04:14 AM
tooltec's Avatar
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
5x120PCD ,(5 bolts M14x1.25mm).17" diameter wheel.
Old 09-20-2010, 04:47 AM
Alex-F10's Avatar
?? ??? ? ?????, ??? 8JX17 ET:30, ? ??? ????? ??????? ???????????? ????????? ? ????? ???????
Old 09-20-2010, 04:51 AM
Alex-F10's Avatar
Thanks,
but what about DIA? is it same as on E60 (72.6)
Old 09-20-2010, 10:09 AM
tooltec's Avatar
Thanks,
You mean centre-bore.I assume it is 72.6mm but I cannot confirm.
If you are considering putting F10 wheels on the E60,the bolt size is not the same,it is M12x1.5mm.There will be less contact area on the conical seat using the E60 bolt.
Old 09-20-2010, 10:48 AM
Gene's Avatar
bore size for the f10 is the same as the e60...
Old 09-21-2010, 02:38 AM
Alex-F10's Avatar
I'm going to use this weels http://rial.de/_rial/index.php/en/salerno for winter tyres on my F10, but I'm not sure whether it is possible
Old 09-21-2010, 05:53 AM
protams's Avatar
My Ride: 530iA 04
is it possible to put 16" on F10 brakes?
Old 09-21-2010, 05:59 AM
Alex-F10's Avatar
I'm going to use 8JX R17 ET:30
Quick Reply: Question about F10 OEM wheels?
