Who knows parametres of OEM 17" wheels (design 236)?
I know that it is 8JX17 ET:30, but who knows DIA and PCD? |
?? realoem.com ?? ???????? ??????? ??? ?????? ???? :thumbsup:
Originally Posted by Alex-F10
(Post 1241035)
Originally Posted by v_therussian
(Post 1241043)
Originally Posted by tooltec
(Post 1241059)
5x120PCD ,(5 bolts M14x1.25mm).17" diameter wheel.
but what about DIA? is it same as on E60 (72.6) :question: |
(Post 1241069)
Thanks,
but what about DIA? is it same as on E60 (72.6) :question: If you are considering putting F10 wheels on the E60,the bolt size is not the same,it is M12x1.5mm.There will be less contact area on the conical seat using the E60 bolt. |
bore size for the f10 is the same as the e60...
(Post 1241212)
You mean centre-bore.I assume it is 72.6mm but I cannot confirm.
is it possible to put 16" on F10 brakes?
Originally Posted by protams
(Post 1241677)
