F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
No power or ignition at all after accident
Old Jan 20, 2023 | 11:13 PM
emkaemsis's Avatar
My Ride: Bmw f10 535i carbonschwarz metallic - beige comfort seats
Default No power or ignition at all after accident
Hello, I recently purchased an f10 after a minor accident in which the airbags have blown. The trunk is closed, there is no power in the car at all probably because the battery is dead. I tried jump starting the car by connecting positive and negative terminals to a jump starter but still no power or ignition at all, no signs of power. What should I do next? I can see that the fuse box has been left open from the auction, maybe that has something to do with the cars power?
Old Jan 20, 2023 | 11:27 PM
donpb's Avatar
My Ride: '06 530i N52
BST cable can blow during an impact. Check for continuity with a multimeter.
Old Jan 20, 2023 | 11:31 PM
emkaemsis's Avatar
But, as I read, the BST only cuts the power to the starter, the interior electronics should still work from jump cable's power.
Old Jan 21, 2023 | 12:21 AM
donpb's Avatar
So, your car worked just fine until after the minor accident? What does your battery voltage read?
Old Jan 21, 2023 | 02:13 AM
emkaemsis's Avatar
I do not know if the car worked fine before the accident. The battery is dead and it is locked in the trunk so I can't check the voltage.
Old Jan 21, 2023 | 05:51 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You check voltage from the hood not the trunk. You'd also charge the battery from the hood. What are you actually trying to accomplish? If your BST is blown you'll have to open the trunk to be able to do anything.
Old Jan 21, 2023 | 02:50 PM
donpb's Avatar
You'll need to get inside the trunk eventually. Use the manual key.
Maddog-99
Aug 21, 2012 10:17 AM
whitebmw22
DIY: Do It Yourself
Oct 16, 2008 02:38 AM
vishwen
Jun 22, 2008 08:48 AM
KMonster
15
Mar 5, 2005 11:12 AM
Doctor Diesel
Jun 10, 2004 06:16 PM
