F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
iPod help
Old Aug 11, 2013 | 03:19 AM
boots's Avatar
My Ride: 2008 550 sport with all the fixins, 07 yukon with all the fixins.
Default iPod help
My iPod worked fine in my e60 using my cord purchased thru BMW. It will play in my m5 but I have no display or control thru the car. Any guru out there for help?
Old Aug 11, 2013 | 11:57 AM
Gene's Avatar
are you using the Y cable from your e60? if so, you shouldn't be...you should be using the standard apple cable...
Old Aug 11, 2013 | 04:56 PM
boots's Avatar
Hi gene
Yes it's the Blk one w the USB/aux conn. my iPod is the old style 80gig. This is the same cord I used in the other car. Don't see what made the diff.
Old Aug 12, 2013 | 06:27 AM
Gene's Avatar
Originally Posted by boots
Hi gene
try the white apple cable...see if it makes a difference...
if that doesn't work I'm wondering if it's an OS issue with your early gen IPOD...what OS is on that?
I have the first gen ipod vid 80gb...I use it basically as my music HD now....the whole sroll wheel on it seems so outdated, lol..but it's still a solid piece of tech...lol
Old Aug 12, 2013 | 01:25 PM
boots's Avatar
Ok I found my white cord. It works. Thanks gene. Yep it's outdated but lots if good music on it
Old Aug 12, 2013 | 06:36 PM
Gene's Avatar
glad that got it sorted for you
bestofthebest
Mar 28, 2016 02:47 PM
bestofthebest
Jan 5, 2016 07:47 PM
umichchris
Dec 7, 2015 03:33 PM
Bank$hot530
Sep 16, 2015 01:28 PM
kcrokin
Aug 20, 2015 03:54 PM
