F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
How to check differential for damage
Old Oct 30, 2024 | 05:49 PM
ShanR's Avatar
My Ride: F10 Bmw 550i LCi
Default How to check differential for damage
Hi
Purchased a 2016 550i with broken rear driveshaft (driver side) not sure how or when, as I bought from auction.
Rear wheels wouldn't move when in drive mode on the ground. Rear passenger shaft wouldn't spin on the ground but it would when it was on ramps.
I've removed both drive shafts and the driver side broken at CV joint. Rear passenger side looks ok but can't be sure.
Question is, how do I check if the differential is ok or needs replacing? The oil has no metal, the gears and pinions look fine with a endoscope camera and there was no diff noise. Can I check the diff by putting the car into drive whilst it's on ramps? Whats the Best way to see if Diff needs replacing?
thanks
Old Oct 30, 2024 | 05:56 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You scoped it and looked at the fluid. At this point I think you've done all you can to check it. The only thing you have left is to fix the shaft and drive it to see what happens
Old Oct 30, 2024 | 06:43 PM
ShanR's Avatar
I agree, but putting everything back together again and finding out it does need replacing would frustrate the hell out of me.
Car is on jack stands and having to remove the exhaust and the prop shaft to replace the diff all whilst lying under the car, is what I'm trying to avoid.
I just want to make sure i haven't missed anything in the diff?
Old Oct 30, 2024 | 06:50 PM
I get it. To me you've done what anyone would do short of taking it down and opening it up.
Old Oct 30, 2024 | 07:10 PM
ShanR's Avatar
So if there are no metal shavings or bits in the oil and the gears and pinion looks fine then there is likely nothing wrong, you would say?
Old Oct 31, 2024 | 02:13 AM
That would be my assessment barring the seal looks good.
Tattoo Tom
Oct 17, 2020 07:39 AM
jadidaskv
Jan 21, 2020 03:23 PM
resunoiz
Jan 7, 2015 04:15 AM
lcc014
DIY: Do It Yourself
Feb 22, 2010 11:32 AM
twssas
Nov 3, 2009 04:27 PM
