F10 Discussion Anything and everything to do with the F10 5 Series. The F10 made it's debut in 2010 as a MY2011.
EVERYONE WITH X-DRIVE
Old 07-29-2011, 04:16 PM
Darkyy's Avatar
Hi , everyone with X-drive i want to ask does you feel any understeer with a car ? going fast - mad on turns ?
Old 07-30-2011, 09:58 AM
v_therussian's Avatar
I've got no understeer on my E60 with X-drive...
Old 07-30-2011, 11:02 AM
Darkyy's Avatar
really ? how does it feel like you go in corner and press pedal to metal does it gonna slide on its front wheels? does it have RWD feel ?
Old 07-30-2011, 05:01 PM
geobmw's Avatar
My Ride: 2011 550i M-Sport xDrive
Model Year: 2017
F10's xDrive has a default front/rear torque split of 40/60 percent. During cornering, it moves to a 20/80-percent split to counter the understeer. It is very close to RWD feel during cornering.
Old 07-31-2011, 12:07 PM
Darkyy's Avatar
thanks , at the stop if you turn all aids off , and if you press pedal to the metal will it chirp tires?
Old 07-31-2011, 02:04 PM
geobmw's Avatar
Model Year: 2017
Yes, check this out:
Old 07-31-2011, 03:24 PM
Like I said, I've got an E60, so it's a little different. But mine sticks like crazy. In less layman's terms, it has a neutral bias when it comes to cornering. When you push hard into a corner, the car will go in neutrally, without any bias. If you late-brake and carry a little too much speed, it will slightly understeer - not so much that it would lose traction at any of the wheels, but enough to let you know that you need to floor it early in mid-apex. When you push down the go pedal at the cusp of the turn, the car carries through neutrally. If you carry way too much speed, it would under- and overstreer equally - i.e. neutral bias. In my experience with this car, the way it sticks in corners is like nothing else. When I did it on some closed circuits with several friends in the car - and mind you, since I had people in the car, I went only at about 8/10ths, not 12/10th all out, as I'd do when I'm alone - they were stunned. IMHO E60 platform still kicks ass of the F10 platform when it comes to this kind of driving. Unfortunately, they are somewhat "underpowered" compared to the F10's and lack the modern electronics.
Also, I would imagine that F10, relative to E60, would lean more in turns, causing more tire and body roll, resulting in slower max speed through corners. But F10's smarter torque transferring systems, and rear-wheel bias of the X-drive, combined with the adaptive drive (ARS did not come on Xi E60's), has some serious potential. Remember also, my car has a 6 cylinder engine - V8 is heavier and will cause more weight distribution to the front = more understeer.
Hope this helps. Honestly, I hate understeer - to me, that's the absolute worst quality of any car's handling. It's the reason I've switched from Audi to BMW in the first place. I'm not a huge fan of oversteer either, but at least it's more fun
hurst01
F10 Discussion
11-09-2014 12:50 PM
Mr.PC
04-13-2011 10:17 AM
JayArras
01-09-2011 06:01 PM
ssukduang
11-24-2010 09:25 PM
ForbesZ
05-12-2008 10:58 AM
Quick Reply: EVERYONE WITH X-DRIVE
