BMW 535i Xdrive 2011 - Crank noice after shutoff
My Ride: 2011 535i XDrive
Hi
BMW 535i Xdrive 2011 - Crank noise after shutoff , I was in BMW dealership and try used 2011 535 x drive but noticed that car was making crank noise after shut off. sale man told me that car is not shutoff properly.
is some has the same issue or same behavior?
how can we fix it or prevent?
Thank you
IZ
Thank you
IZ
My Ride: 535i
Model Year: 2011
Hi
Thank you
IZ
Thank you
IZ
The dealer tried to replacing this module under the valve cover, kinda like a PCV valve but that never worked. Said that squealing noise was the rear engine seal so the replaced it under warranty. Too much pressure in the engine.
The noise would stop as soon as I unscrewed the oil filler cap but start up again when you put the cap back on.
I think this is common problem.
All good now
