2013 535i xDrive Oil pan gasket parts list needed...
Probation Members
My Ride: 2013 535i xDrive m-sport
I'm new here an to BMW's. Just bought my wife an 2013 535i xDrive with 99k miles. Bought it knowing it needed the Valve cover and Oil pan gasket replaced. I already did the Valve cover gasket (w/aluminum valve cover), Trans pan (w/aluminum pan), and rear end flush last week. I am now ready to do the oil pan gasket and have ordered most of the parts, but I'm having a hard time finding ALL the little part numbers for all the bolts/nuts that I will need to replace. Such as the bolts on the front drive shaft or the mounting bolts for the front diff. Does any one on here have a detailed parts list of all the new parts needed to do the complete job? Also is there any other parts I should be looking at replacing?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I don't see where any bolts need to be replaced. In TIS it only specifies fluid and gaskets being changed. I would replaced the engine mounts since you will be undoing them.
On your vehicle TIS does not cover the procedure in its totality as it covers other repairs around it but those repairs do not indicate one time use bolts as I assume they are probably low torqued.
mp333
05-05-2017 06:37 PM
