Xenon headlight wires
Probation Members
My Ride: BMW E61 525D 2004
![Arrow](https://5series.net/forums/images/icons/icon2.gif)
Hi,
I have a BMW E61 525D 2004 and I have a problem with my xenon headlight, I changed the xenon and the ballast but it was still not working. I already gave up on it but then my battery died and after I charged my battery and messed around with the wires in the trunk my headlight worked again (hallelujaa) but again after I put back the wires and stuff in my trunk the headlight was not working again
So I think I have some contact failure with my headlight wire around the fusebox but I am not sure which wire in the trunk is responsible for the headlights
Does anyone had the same issue and have a solution? Or do you know which wire can be the problem?
thanks in advance!!
thanks in advance!!
