wiring under center console?
I popped off the rear panel of on the center console in my 2008 535xi to fix a bad aux input connector and found what looks to be several unused wires. There is a male satellite cable connector and another connector with 4 wires that doesn't go anywhere? Does anyone know what these are for?
Specifically, I was curious if the sat cable goes to the roof antenna because I was wanting to use the satellite cable for an aftermarket xm radio so I don't have to mount a separate antenna. Odd part, though, is the male end to the cable.
Thanks!
Thanks!
PelicanParts.com
07-23-2015 12:50 PM
PelicanParts.com
07-23-2015 12:41 PM
PelicanParts.com
07-10-2015 02:57 PM
