What battery for 535d?
My Ride: 535d M Sport Touring
Still having starting issues and still waiting to get it booked into auto electrician but decided to phone stealer today to see how much new battery is for '05 535d.
Mr Vague in service tells me I have a choice of 3:
80 amp - ?134
90 amp - ?153
110 amp - ?173
He has no idea what 535d "should" have, and as mine wouldn't start again today (supermarket delivery chap knocked the trickle charger off it last night so dead as a dodo this morning) I can't look to see what I currently have as I'm at work.
What one should I go for or is the Bosch one at Halfords tried and trusted?
TIA
Fiona
80 amp - ?134
90 amp - ?153
110 amp - ?173
TIA
Fiona
My Ride: 07 E61 530d M-Sport.
That Bosch battery looks good. The only thing is that you will still need to go to the dealer to get the car initialized for the new battery. Unless it's exactly the same capacity and rating as the old one. You can see the old battery in the boot behind the trim panel on the r/h side, all the details should be on the top.
My Ride: 2008 550i sport
My Ride: 535d Sport Tourer - E34 M5 Race Car
Hmmm, I just walked into Halfords, found a battery with the same Ah, put it in and everything worked, and still works 1 year later.
Maybe just lucky
Maybe just lucky
My Ride: 2004 March E60 530i, Titanium Silver with Black Dakota Leather, Style 124 18" Alloy, Active Steering, Adaptive headlights, Auto-Dim Int+Folding Ext Mirrors, Auto Aircon Advanced, Brushed Aluminium Trim, CD Changer, Comfort Seats, De-Chrome, Dynamic Drive, Electric Glass Sun Roof, Graduate Tinted Windscreen, Heated Front Seats, Natvigation Professional, Sport Steering wheel, Sun Protection Glass, TV function
80 amp - ?134
90 amp - ?153
110 amp - ?173
TIA
Fiona
80 amp - ?134
90 amp - ?153
110 amp - ?173
TIA
Fiona
Hi. Fiona's hubby here.
The battery isn't knackered it's just being drained at 0.8amps as something is staying on when car locked.
Battery is a 90amp BMW one so should be adequate except when lost it's charge. For an expensive car the issues everyone is having with battery drain seems like poor design or poor componants.
Are there any signs of things not working properly? When I had that message I had an electric window not working properly so the Body control module was replaced and later when the message was still there the rear window and parcel shelf were unlocking themselves while the car was running but stationary. They boot control module was replaced and the fault has never come back.
The other thing with cars when they are this complex is that they aren't so easy to diagnose when the fault is intermittent or not logged as a fault.
Used to get Increased Battery Discharge warnings in the mornings and struggled to start, but don't get that warning anymore.
When battery was very low got a couple of warnings flick up. Window shut safety mechanism warning and power steering warning, though I'd guessed these were due to the battery being almost flat.
Clock time goes to 00:00
Sunroof can need reinitialising
Windows can need reinitialising
Steering angle sensor can need reinitialising
You can set all yourself without needing any equipment.
The car does drain a lot of current, I think something like a couple of amps just with the car unlocked and the computers booting up. Even once locked it takes at least 16 mins to shutdown, can be as long as 80 mins!! You need to measure the current at this point to see if you have a current drain problem.
Vman33
03-14-2022 04:43 AM
