Trying to Find a short
Old Jan 17, 2021 | 02:25 PM
2006 530xi's Avatar
My Ride: 2006 BMW 530XI
Default Trying to Find a short
Fellows, I have been experiencing a nasty Battery drain on my car and is driving me nuts. I will be driving fine and go to a place, turn OFF the car , go do my work and come back and Car won't start because battery is drained down below 10 Volt. I had taken the car to a BIMMER shop and they told me it was the MPM module in the trunk. Car was fine for a couple of days and again its doing the same thing. I inspected all the modules in the Trunk and cleaned them up. I also relocated them.
Battery is brand new. Alternator is putting 14.4VDC when its charging.
I even installed a SHUNT in Series with the negative battery wire and When I shut the car off, I watch the module shut down current that drops to 40ma. 40mA is not going to drain my battery. I have not determined if the IBS is the issue.
One crazy thing I have noticed is that once in a blue moon, my Right side passenger door window won't go up or down. And also today I noticed that when I opened the Right side passenger door, My battery voltage dropped down to 9.8 Volts. Just I have not really get a constancy to say the door is the problem., I have been having nothing but electrical issues with this car. Also, this issue does not show up as often if I park my car Flat or Downward angle like my rear of the car a little higher than the front.
Are there any Computer modules inside the right side door that is prone to water damage and corrosion? Any other place i should look?. I have already repaired the hatch wiring harness problem.
Old Jan 17, 2021 | 03:24 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Personally I would shut the car down and test fuses. Seems like you've done a few things but you're going to waist a lot of time and money tracking it down unless you start probing.
Old Jan 17, 2021 | 04:41 PM
2006 530xi's Avatar
Problem I have is there is no high Current when I am around. I am thinking putting some kind of data logger on it to see if it wakes up when I am not around.
Old Jan 17, 2021 | 10:32 PM
donpb's Avatar
My Ride: '06 530i N52
Or buy a BMW Code reader.
Most I've owned will show a histogram of the battery charge status (and display faulty modules to boot).
Old Jan 18, 2021 | 04:46 PM
2006 530xi's Avatar
I have access to INPA but not ISTA. I also have a foxwell. INPA does have some kind of energy management tool.
I am wondering if it has something to do with my Air bag modules. I have the following codes.
00 ZGM OKAY 1 Error stored 932F 28
01 SIM/SGM OKAY 2 Error stored 93F9 60 93FC 20
12 DME/DDE OKAY 3 Error stored 29F5 A1 29F4 A1 2C7F 80
18 EGS OKAY 1 Error stored 51AD 24
19 VGSG OKAY 1 Error stored 54C6 61
29 DSC OKAY 4 Error stored 6F51 A0 D358 A4 5EBA A0 5DCE A0
38 EHC OKAY 1 Error stored 5F97 A1
40 CAS OKAY 1 Error stored A0B2 20
45 RLS OKAY 1 Error stored DA44 20
60 KOMBI OKAY 2 Error stored A3AA 20 E107 24
70 LM OKAY 1 Error stored 9CC3 22
78 KLIMA OKAY 2 Error stored 9C55 61 9C7B 62
A2 SBSR OKAY 1 Error stored 95B7 60
Old Jan 18, 2021 | 04:58 PM
Why would you say it has something to do with the airbag module?
I'm looking at all these codes and it seems like something electrical is going on. Are you sure the battery is good? It would coded and registered correctly. I would clear all codes and dive it for a day and see what comes back to narrow things down.
Old Jan 19, 2021 | 06:59 PM
2006 530xi's Avatar
I am going through these codes one by one. The Reason why I am suspecting the module if any on the passenger Door is that When I open and close that door, this failure seems to show up. I also have the Air bag light on with the Seat belt Red light. At first I thought it had something to do with the occupancy sensor but the more I think about it is the Air bag module or some kind of module in that door.
The interesting part is that if I park the car backward in my drive way with slight incline, this problem does not show up but if I pull in with Engines side higher than the tail, it seems to show up.
I tried using INPA to register the battery, it would not let me and give me an error. I am not sure if my car does not have this feature or I am doing something wrong.
This weekend, I will try to put a data logger on my car and play with the doors on the right side of the car.
I also found a burned up module 61357188110-01 which it was in my trunk tire space. At first I thought I found it but long after I pulled the module out, that issue still showed up. I am not 100% sure what this module exactly does other than I saw Hatch Control Unit on one of the websites. Right now that module is not in.
Another Suspect is the Rear Air suspension. I am keeping an eye on it.
I can't believe the amount of issues this car has with electrical end. I am using it to commute to work and it is smooth as hell. 26mpg. One by one, I will find them hopefully. I really want to learn how to code these modules myself. Still learning the methods.
Old Jan 19, 2021 | 11:23 PM
donpb's Avatar
You probably have some wiring harness issues (exposed wires).
Old Jan 20, 2021 | 09:45 AM
glyph's Avatar
My Ride: n54 e61
Does your car have comfort access?
Old Jan 24, 2021 | 04:43 PM
2006 530xi's Avatar
I am not sure? I am still learning what this car has. Freaking very cold outside to work on this car right now.
