Trunk door struts
My Ride: 523i Touring
Hi guys,
i need to to change the struts on the trunk door. Has anyone done this, is it easy to do?
what struts do you guys recommend? I’ve seen some for $40 a pair and others for t times that.
any help is appreciated
thanks
thanks
My Ride: E61 525dA, High Executive, Xenon (AHL), leather+memory, CCC Prof, pano-roof
Engine: M57 (256D2)
Hi,
I have changed them a couple of months ago. You can do it within 5 min for both sides. Just unclip the metal clip on the top-mount with a small flathead screwdriver. Then you can pop it of easy.
New struts: just click in place and done!
I have bought the struts from the Stabilus brand. OEM BMW also uses Stabilus.
Engine: M57 (256D2)
by the way: Make sure somebody else will hold the trunk door for you when you pop-off the strut. Otherwise it will fall down on your head. One remaining strut will not hold the trunk door open....
If you don't have a third hand to help, you can always use that plastic support beam that's under the cargo mat. Pretty hefty and can/will hold the weight of the rear hatch.
umnitza
12-16-2013 11:36 AM
umnitza
06-28-2013 01:10 PM
530iM
05-11-2012 07:15 AM
pennetta
03-09-2010 03:33 PM
nigxdoof
06-11-2007 09:29 AM
