Touring rear suspension failures
#271
My turn to have a "closer look" (meaning biting the bullit) at the levelling system. Bags are replaced a year ago. Error comes up almost daily now. Switching on and off works but the next day its the same story.
Its the control time error which indicated it takes to long to get it on level. Car doesn't "hang" low on either side. Each day i hear the compressor and sometimes it gets the car on level just before the threshold time. I think the threshold time is about 1 minute or so.
Next step is replacing only the valvle unit but I think i'm in for the whole unit considering it takes too long to get the car on level assuming the intake pipe and filter are not the main culprit.
reg
willem
reg
willem
#272
A leak anywhere in the system could cause the problem you're seeing (or, a worn-out compressor, as well). I'd try hitting everything visible with a schpritz of soapy water to see if you can find a leak somewhere. I almost never hear my compressor run, other than when I'm lifting one end of the car or the other (always fun to drop the car all the way to the ground after having the rear lifted with a floor jack and the pneumatic system airs down totally to "correct" the stance with the rear wheels dangling). ;-)
#273
https://aerosus.nl/bmw/5-series/e61/...hoCt30QAvD_BwE
#274
FWIW, you might be able to "test" the system by doing what I do when working on the back of the car... When the car has been jacked up with the rear wheels dangling for a while, even with the key off, it wants to "correct" the stance, and will eventually let all the air out of the bags. Then when I release the floor jack, the back of the car goes to the ground, and the pump starts running to bring it back up to the right height. It only takes ~30-45 seconds IIRC.
If you did this, if the car takes a lot longer, AND if both sides seem to be acting the same, I'd suspect the compressor. If one side comes up a lot faster than the other, I'd look at the plumbing on the "slow side".
#275
w
#276
The culprit is clear. Snapped intake hose right at the niple of the compressor. I don't know how long its already broken but the pump runs way too long an dalso on a daily basis passing the threshold times sometimes resulting in the dash notification. The fact that it kicks in each day is a sign of vavle-unit leakage. The high pressure tubes and airbags are new.
Decided the replace the compressor, the vavle-unit, intake hose and relais. The lot comes from aerosus.nl with a 2 year garantee.
w.
w.
#277
I'm lazy, so would have tried to replace just the nipple. ;-) But replacing the lot sounds like a great long-term play (you'll be done fiddling with the rear pneumatics for a long, long time).
#278
reg
willem
#279
Yet again another development of the story. Last friday we checked the compressor and hoses and decided to order a new set.....But...since then I got NO errors anymore and I've got only 1 explanation. The intake hose snapped while we were at it. This would mean the intake-hose WAS still connected but with a clogged up filter or so causing the compressor to take ages to get the car on level. Not sure but we cancelled the replacement for now and see how it develops. We'll replace the intake hose and filter for now.
keep you posted
w
keep you posted
w
#280
That would certainly fit the symptoms, though I could also easily believe that there may have been a funky connection at one of the other points (I really don't like the "feel" of the tightening of the air line output lines - it always feels like it's barely hanging on, or is ready to break.
But hey - if it's working, don't mess with it! ;-)
