Tailgate wiring harness replacement??
#402
My Ride: 535xi Wagon
awesome find! thanks for the info.
An update - I fixed my wife's e61 remote. As I mentioned before, e61 diversity antennas are not on ebay. I found an e63 diversity antenna on ebay ($40!), that looks identical. I moved the board over to the wagon, and it works! An added benefit, probably from the harness repair, is that the range is now 'normal' - about 30 feet. Previously, I had to be right next to the car to open it with the remote.
The part number of the e63 antenna is 6934485-02. I bet E60 antennas work as well.
Make sure the connectors look identical.
An important note: I had to have the AM antenna hooked up - the Black connector - for the remote to program.
Hope this helps someone in the future.
Samir.
Samir.
#404
My Ride: 530d 2008 (58) E61
Hi all,
Signed up to this forum to say thanks for all the guides and Input from all the individuals on here. I have a 58 plate 530D, it currently has a rear left fog light and rear left reversing light failure. Can anyone confirm where I'll find these wires? I guess they'll be on the left hand side?
Many thanks, Lucas
Many thanks, Lucas
#405
Hi, does anyone know for sure which wires deal with the soft close realising the boot is shut (and what side it runs down)? The mechanism all works OK by the tailgate switch (can see it spin), however, we have replaced all split wires we could see, and still no luck (so was hoping someone had a definitive answer before we have to put a multimeter on all wires
Sure it will be a wiring issue, as the boot started to not pull closed, then would work fine for a few days, and got progressively worse, to the point now that it wont pull shut at all.
Many Thanks
Many Thanks
#406
My Ride: 535d Touring
Hi,
535d Touring (2007)
Thanks for all the contributions to this thread. I'm having the soft close boot not closing properly issue as well as occasional battery warning and glass boot not opening now. Certainly seems like the wiring loom issue.
Unfortunately I'm not skilled enough to attempt the fix myself. Can anyone recommend an auto electrician they have used that charged a reasonable price to have the loom replaced? I'm based in the Midlands (UK).
Also is the SenCom kit still recommended as the best replacement?
Many thanks in advance!
535d Touring (2007)
#407
Anybody had this done in the Midlands UK? Recommendation would be really helpful!
Thanks!
Thanks!
Hi,
535d Touring (2007)
535d Touring (2007)
#408
Thanks for the tip sshobby on the E63 diversity antenna module - I've purchased one on eBay - when it arrives I hope it will solve my loss of remote entry (for the second time) on my E61.
#409
My Ride: E61 523i
I was facing issues with locking and unlocking, radio signal and rear glass heating. I purchased the Sencom wiring loom and took it down to Simon at A.C.O Motors ltd, Shutt Lane Earlswood B94 6DA, 01564 702 732. He is a great guy, professional and knows his stuff. I was recommended him by a fellow member and drove up to him a couple of times from London, the price is reasonable. If you do end up going to him, tell him I recommended you (silver estate from london).
I hope your issue is sorted out.
Katitu
#410
Hi,
Katitu
Katitu
Thanks for the recommendation. Apologies, I've only just seen your reply as I didn't get a notification! I've got the car booked into Hughes Brothers Derby so will update on how they do. Heard good things about them so fingers crossed.
Thanks again
