Last week I noticed a strange 'plastic grating' sound when opening the tailgate. :think:
On closer inspection the left (Nearside) tailgate strut had developed a longitudinal split, right along where the part number is imprinted. At the dealers today they noticed that the right strut was also showing signs of imminent failure, there was a slight deformation in exactly the same spot as the left one. Both were replaced under warranty. :thumbsup: The tailgate now opens much smoother and feels lighter than it ever has. |
Good warning. Mine is May 2004 and had the same problem last year.
By virtue of the dealers having the parts in stock, it cannot be too rare a problem !
Mine is also May 2004. Off side went and had it repaired under warranty in June. The dealer didn't have in stock.
I agree the tailgate now opens much smoother and feels lighter than it ever did before. |
I just noticed the same problem today. Back to the dealer. I hope they have in stock.
Hi,
I've always felt that mine is quite stiff to open... I mean it's not easy/light to lift up the hatch. I've been wondering can that be adjusted somehow.... or should I get replacements parts. how smoothly E61 tailgate should be opened anyway. :) |
Had the same issue on my Nov 05 525d Tourer. Onday it just didn't open as well as before and i noticed bits of plastic on the boot (sorry, trunk :P ) floor. Took a look and sure enough it had split. I use the 'trunk' a lot so it was a pain given the trunk no longer opened as far AND i was concerned that it might explode or similar :nono:
Regardless it was changed under warranty with no issues. |
Had the same problem. Strut split and I think it was due to my wife closing the lid from one side rather than the middle. Replaced under warranty with no issue at all.
I have had both struts replaced.
Now - the car is going in again to have the motor which retracts the load area cover to be replaced. Any others had this fault? The car is 2yrs 9mths old, I wonder if the motor on the other side will fail before or after the 3 yr warranty expires? Still enjoying the car though. |
Are you shure that it's the motor? There is a mod for the roller pin to one with bearings instead of bushings.
